The ASIair Plus uses a very useful file naming taxonomy/structure when saving files internally but seems to use a less useful numeric sequence when saving files to the DSLR’s memory card. For example:
- ASIair saves file to internal memory as: Light_M42_240.0s_Bin1_ISO1600_20230212-195555_0001.FIT
- ASIair saves the same file to DSLR memory card as: _7502844.NEF
Is there anyway to customize the file naming taxonomy/structure to add the same level of detail to the RAW (NEF) file which is saved to the DSLR?
