OklahomaProf1940 I apparently don't see all the popups you seem to indicate in your reply.
Ah, OK. Is your Android simulator using a real keyboard instead of a virtual keyboard? If so, try hitting the Enter key or Return key on the keyboard right after entering the numbers.
This is what I see on an M1 Mac with a real keyboard (running the ASIAIR Beta). Notice there is no virtual keyboard.
Notice that I had clicked on the "edit" icon (a rounded square with a pencil across one diagonal, on the far right of the Exp(s) field) and that I had entered 302 seconds. So, in addition to entering the "302," I also have to hit the "Return" key on the physical keyboard.
When done, click on the "OK" button.
