Yes, if you are connecting the ASIAIR to the hand controller port. I assume that means you don't have a USB port on the mount.
Using the hand controller, follow the EQ6r manual to program PPEC into the mount (you should only have to do this once). Then go into the Setup menu and select Tracking/PEC+Sidereal. The led on the mount will start blinking in 3's. Now hook up the ASIAIR and go from there. You'll need to enable PEC+Sidereal each time you power cycle the mount.
Personally, I haven't found that PPEC has improved my guiding, so I don't bother to enable it.
