PhotomanTom “first delay” and “interval” in the auto plan menu
For AutoRun and Plan modes, First Delay is a timed delay from the time you start the sequence until the first exposure begins. This lets you start the sequence an hour after you have gone to bed.
Interval is the time between exposures. Exposures can be 0.1 second long, while the interval can be 10 seconds, for example -- in which case, you will get 10 frames every 100 seconds, but each frame is only exposed for 0.1 second.
