I recently acquired iOptron Cube Pro.
However, it is hard to find any information to use this mount in EQ mode with ASI AIR pro. (onlya few fi ndings-like this page. [https://stargazerslounge.com/topic/396569-the-ioptron-smartstar-cubepro-8200-go2nova-8408-w-aaeq-dual-mode/] It sounds like this person succeeded to use his mount with ASI AIR pro.
Unfortunately, this person does not explain much about how it is connected. iOptron Cube Pro has Go2Nova 8401 hand controller (with USB-B port on the controller to connect with a computer) so if I connect my ASI AIR pro with a USB cable from the hand controller to the USB port of the ASI AIR pro, can I control the mount with ASI AIR pro? Or do I need any other cable for connection? I understand it is a kind of necessary to use the hand controller for connection.
