That adapter uses a T2 (i.e., M42x0.75) interface to a camera that has a flange-to-sensor distance of either 12.5 mm or 17.5 mm. Any adapter from M42 to the M54 thread of the camera will need to be either precisely 5 mm long, or zero mm long. If you add filter glass, you will need an additional spacer that is 1/3 the thickness of the filter glass.
The bigger problem, if you are using it with a ASI6200, is that you will get severe vignetting. The hole size of the T2 interface is only 37.3 mm (I just measured), while the diagonal of your full frame sensor is 44mm. The hole needs to be substantially larger than 44mm -- especially with an f/1.4 lens -- to prevent the hole from obstructing the light cone from the lens.
Even if you can use flat frames to reduce the light drop-off from vignetting, the aperture vignetting causes pretty severe ugly diffraction notches in bright stars that are only half way from the center of the ASI6200 frame (which cannot be corrected with flat frames).
Depending on the f-number of the lens, you could get vignetting even when used with a smaller APS-C sized sensor.
Caveat Emptor.
