taurus81 Tried auto white balance on and off but no help as well as numerous other settings.
RAW images are just that, data that is collected originally by turning photons into electrical currents. It does not, and should not, be alterable by any settings such as white balances; otherwise it could no longer be called RAW.
RAW images from CMOS cameras do not have color. Every pixel is monochrome, overlaid by a Bayer mosaic.
Color balance is applied when you create a non-RAW (e.g., JPEG) full color image from a RAW image.
If you see a green tint, it is possible that whatever program that you use for debayering did not account for the fact that each Bayer superpixel contains two green subpixels, but only one red and one blue subpixel. Or, it could just be that the quantum efficiency of the sensor is higher at the green wavelengths (usually true).
Just apply color balancing after you post process the RAW image(s).
