ASI120MC: I started capturing an object inside my house (it was a plant 1 km far from my building on daylight, around 12 PM, and later the camera stopped recording any image (it was not focusing anything). I used a Maksutov 90mm. Is there something wrong with capturing things at this period or perhaps the Sunlight interfered after a while?
I had the same problem using Sharpcap or Firecapture.
In the beginning, the camera even recorded twice, it was all OK, but as I said, after a while it didn't showed any image from what was outside my house.
I know this is a planetary webcam for use at night and for astronomical use, but it was recording just fine when I tested this way.
P.S. I haven't tested at night yet. Perhaps when the Sun light interfered a little more the camera didn't recognize any image from that area anymore? I didn't point the camera to the Sun, but the area where I was recording had Sun light over the objects.
Another problem is the BUGCODE USB bluescreen in Windows 7. Sometimes it happens all of sudden. Is there a way to fix this for good?
