tempus Can you point out where you see those strong fifth harmonics?
Places like this:
See that there are 2.5 cycles (or so) per 1/2 a period of the 430.82-sec fundamental?
Notice that it does not pop up everywhere, and that is why I mentioned the non-stationarity property to use frequency domain analysis.
https://en.wikipedia.org/wiki/Stationary_process
and you cannot use Fourier transforms with non-stationary signals:
https://www.quora.com/Why-is-Fourier-transform-not-suitable-to-analyse-a-non-stationary-signal
You really need to know the limitation of tools, and why and how they work, before using them blindly.
There is something called the Short-time Fourier transform (e.g., using very short FFT windows) that you can use to see these short term artifacts:
https://en.wikipedia.org/wiki/Short-time_Fourier_transform
Note down the hour angle (the angle where the OTA is pointed to relative to the Meridian) of the mount at the time it appeared on the graph above.  In the future, if guiding suddenly gets erratic, compare the hour angle of the mount to what you have noted down, and if it appears at about the same time, you will know where the error is coming from, and know that there is nothing you can tune autoguide parameters to help, and thus not waste time.
There are multiple places with your mount, not just the place I screen grabbed.
Notice that the peak-to-peak amplitude of the fifth harmonic is larger than 1/5 the peak-to-peak amplitude of the fundamental itself.  This means that the fifth harmonic distortion willl more than double the slope of the periodic error of a smoother mount.
