My ASIAir Plus ver 2.1 is powered from the AM5 ver 1.3 via the 12V out port which is pass-through (i.e. it's powered even when the mount is turned off). I noticed last night that my Air wouldn't boot if the AM5 is turned on first. I have no issue as long as I power on the Air first then the mount. I suspect maybe it could be due to the mount's USB connection to the Air. I can only guess since there are no system logs available (unless I figure out some way to get a root shell). I'll try different scenarios like unplugging the USB to the mount etc and report back my findings.
Not sure yet if this is a hardware issue (noise maybe??), software (i.e. the new version of ASIAir OS). Wondering if anyone else has seen this issue?
