I am running my ASIAIR from my PC (Windows 10 Home) using BlueStacks (it would be nice to have a native version of ASIAIR running on a PC, not everyone has or wants a cell phone.) I just today inserted a 7-port USB 3.0 powered hub into my system and I have my 4 cameras (ASI183MM-pro, ASI678MC, ASI120MM-mini, and a Canon 5ti) plugged into the powered hub. My hub is plugged into one of the USB 3.0 ports on the ASIAIR and my iOptron GEM45 mount is plugged into one of the USB 2.0 ports on the ASIAIR. The PC-ASIAIR interface seems much cleaner and operates significantly faster with the new hub in action. However, while running the system capturing an autorun series of darks using the 5ti camera, the BlueStacks software still loses connection to the ASIAIR during the autorun process. However, the ASIAIR still seems to keep running and capturing the data while I attempt to restart BlueStacks and regain control. Am I making the correct assumption that the ASIAIR will continue the autorun process even though external PC connection is lost? Thank you for you attention.
