james_screech wrote:You probably have focus so far off that any object is too faint to see. Try focusing on a bright object (planet) with an eyepiece directly (no diagonal) and increase the exposure and you should find a very out of focus circle. You should then be able to focus in on the object and then adjust exposure.
James
What focal length eyepiece would be the closest to that of the camera? So if I put an EP in without a diagonal to get it close to focused, which should I use? The focal length of my scope is 2032mm and aperture is 203.2mm.
Also, if I plan to use a Barlow, do I need to focus the EP with the Barlow installed? Should I center and focus the camera first without the Barlow, then add the Barlow and refocus?
