Hello everyone, I hope someone can help me, I have been using the AM5 mount for about 6 months, so far everything has worked perfectly, but today the mount does not connect to the asiair or to the pc, I already tried with different usb cables and none of them work, I made the connection with the asiair via wifi and so if it works, it connects via wifi and I can control the mount without problems, apparently the fault is in the USB connection, the firmware version I have is 1.1.2 any suggestion?
