Can you set up one auto-run routine for flats for each RGB filter? If so, doesn't this drastically effect the histogram curve with each filter? Or do you have to do each filter separately to establish a prop;er histogram curve?
If you use EFW, you can customize the plan for the RGB filter in Autorun or Plan mode
