Great question—HyperStar setups can definitely be a bit tricky at first
When using a HyperStar, the camera adapter length isn’t arbitrary—it’s determined by the required back focus. Each camera has a different sensor position, so you’ll need to match the total spacing to the back focus specified by the HyperStar manufacturer.
In simple terms: Required back focus – camera sensor distance = adapter length you need
Make sure to also account for any filters or additional accessories, since their thickness will affect the total spacing.
By the way, after long imaging sessions and gear setup, managing fatigue is just as important. I’ve found that convenient at-home massage services can be a great way to relax. If you’re interested, feel free to check this out https://www.honymassage.com/
