Just got my ASIAIR Plus up and running but it will not connect to my A6100 at all. I've been through all the settings a dozen times and the A6100 simply sits at "Connecting".
My A7IV will connect but says that it is not set to BULB (although it is), so the ASIAIR Plus just reports "Exposure Failure"
Anyone got the A6100 to connect to the ASIAIR Plus yet?
  • Marty
    Im also on a Sony A7IV and the app will not recognize that the camera is in Bulb mode its simply not going to work. You can do 30 sec exposures, to fix the "Exposure Failure" issue. But thats it. Hopefully next update fixes that issue.
      6 months later
      I have the same issue with my A6100.
      I have an ASIAIR Pro and Mini, both of them are on latest versions but just sit saying connecting.
      The camera is in Bulb mode. Are there any other hidden settings that need to be set for it to connect?
      Thanks
        @Tech@ZWO Thanks for your reply. I guess I hoped as the rest of the A6000 range was supported, the A6100 would be too. Oh well, back to my old 7D. Thank you.
        @Tech@ZWO Just to mention your pinned firmware post says.
        WHAT'S NEW
        [v2.1-10.74]
        New Feature
        Supported Sony Cameras, some models needs to test
        · A7/II/III/IV
        · A7S/II/III
        · A7C
        · A7R/II/III/III A/IV/IV A
        · A5000/A6000/A6100/A6400/A6500/A6600
          bambi851 It is the change log for ASIAIR V2.1 public test version, and Sony A6100 was removed after test. it has some problems and has not been solved for now.
          12 days later
          Tech@ZWO Its taken pretty much this whole year. Do you think the solution for this exp time problem will be solved before the year ends?
            iErickDGAF Sorry to tell you that I can not give a ETA now, our devs will continue to work on it. we will release here if there is any news.
            Thank you very much for your support.
            4 months later
            ASIAIR 2.1.2 just released today. Does this fix the A7IV exposure issue?
            Write a Reply...
