srlluna Now my PC doesn't recognize it, even if I reinstall the drivers.
Best solution is to return it to the dealer and ask for a replacement for a faulty part (whether the firmware, or the hardware is faulty). The customer should not have to deal with these issues themselves.
If you want to attempt to resuscitate it, try using one of the programs in the ASI Studio Suite. They have interfaces to the EAF, and bypasses pretty much all drivers (the EAF uses the USB HID interface that does not require any driver beyond what is already native in Linux, macOS and Windows).
If the program in ASI Studio program can see the EAF, change the current Step position to 30000, and max Step position to 60000.
If ASI Studio does not see the EAF (or other programs still don't see the EAF after the above step), you can see if the EAF Firmware update program can see it. If so, try to refresh the firmware -- there is an EAF Firmware update tool for both macOS and Windows. Since it is a program from ZWO, this step should not invalidate any warranty exchange even if it keeps your EAF bricked.
