I am sorry for not replying sooner.
Answers to your two questions:
1 I do not park the mount since it is portable, stored in the garage when not in use.
- No.
The LX200 is in a fork mount which is positioned on a wedge, on a tripod sitting on a Scope Buggy. After wheeling the scope outside here are the steps I took:
- roughly point the mount to NCP and then level the tripod
- power the mount which does an initialization and Smart Mount RH movement of 2h40m
- put the scope in the Home position per Meade's instruction (manually set RA to 00h, use hand controller to set Dec at 90 degrees)
- use the ASI Air polar align program, to polar align. No problem with plate solving and mount rotation.
- After PA I select an object to goto but the mount does not move. There are no messages stating that a problem might exist. During this time the tracking LED is still red. It has been red since connecting the ASI AIR to the mount.
Also, does it matter when to power the ASI Air (before or after powering the mount).
