marcdota pre-tapped holes on maybe two sides with extra bolts to cover unused holes
Drilling the holes is really quite easy. And sometimes, you don't want them tapped, anyway.
Just this week, I had found a way to mount an EAF on a RedCat51 tube band without using bulky 3D printed holders.
In this case, the two holes I drilled were untapped M4 body holes.
The shell is first drilled and attached to the RedCat tube band without the internals.
The stepper motor and EAF circuit board are then placed back:
Yep, there is a lot of wasted space in the EAF. Apple's design group would have built a much more compact EAF from the same parts.
And voila, a neatly mounted EAF:
So, sometimes you want an untapped hole, and sometimes you don't.
My use-case is not for a RedCat, but for using the RedCat tube ring (69 mm) on an FOA-60Q's tube (68 mm) to drive the tilt thumbscrew of a SolarScope etalon. Part of the setup, without steel rods and bearings:
But this should work on a real RedCat51 using a follow-focus rubber gear on the helical focuser of the RedCat, and a pulley on the EAF, like what I did on the Borg.
The SolarScope SF-50's tilt screw is friction driven with a thick O-ring:
http://w7ay.net/site/Images/EtalonTiltProofOfConcept.mov
After further experimentation, I decided to keep going outdoors to adjust the etalon tilt, because two extra EAF jigs to adjust a double-stacked etalon is just too much weight to be worth it. The extra EAF, tube bands, stainless steel rods and pillow block bearings is just a lot of dead weight 99% of the time.
Now, what we really need is for astrograph manufacturers to build electronic focusers right into OTA, with a single small USB-C connector for both power and data, and get rid of all the knobs etc that astrophotographers will never ever use. This way we don't have any kludgy and ugly ZWO EAF mounting. The PrimaLuce Esatto is really close to an ideal electronic focuser, but it can be even more compact if built into an OTA to begin with.
