Hi,
I just put together a new rig, which I control using NINA. I have had good experiences with both this software and EAF motors. However, in this new rig, I am running into the following issue:
I set the focuser to its "zero" position (tube all the way drawn in) and then set the EAF to "zero" through the ASCOM interface as well. I then move the EAF to "focus" (which is around 13850 in my setup) - and that works fine. I can disconnect the EAF and re-connect through ASCOM and it will "remember" that it is at 13850 steps.
However, when I power down the rig and re-start it the next day, the EAF insists on being at position "2" even though the focuser is still "at focus" and the EAF should thus read 13850.
Only solution so far has been to uncouple the EAF from the focuser, set the focuser to its drawn in (0) position and re-attach the EAF. But that is really not a good solution long-term.
I have already updated NINA, and updated the EAF firmware.
ASCOM is version 6.5.
Any ideas? Does the EAF maybe use an internal battery to "remember" its position; and that battery is perhaps faulty?
Cheers,
Marc
