So I have an HEQ-5 Mount, an ASI Air Pro, and an EQMOD cable recommended by Starizona.
Yet when I try to connect my mount to my ASI Air via the app, it won't let me connect.
I've tried connecting it with the following connection options:
Skyscan Beta
SkyScan
EQMod
\I've got the EQMod cable plugged directly into the HC controller port from the ASI Air. I've tried all the different Bauds..
It DOES however let me plug the EQmod cable into the HC itself, then plug the HC into the HC port.....BUT I have to do a manual 3 star alignment first via the HC, which is a serious pain in the A$$. Once I complete the alignment, it will then let me connect. But not before.
I updated the HC firmware as well.
Anyone have an idea on what to do?
You could contack support, maybe your air pro need update system driver .
Write a Reply...
