de uma hora para outra a camera asi 120mc nao da imagem no phd2,somente no asicap, ja instalei o melhor drive e o problema continua.
mesk Did you check to connect via ASI camera driver and ASCOM driver in PHD2? both not work?
Or you can replace the ASIcamera2.dll file on the PHD2 installation folder with the same name file on the ASIStudio installation folder to try.
Tech@ZWO vou tentar isso para ver se funciona. Obrigado
BTW, is it an ASI120MC USB2.0 version?
Tech@ZWO sim USB 3.0
