The camera worked at 10 AM as one can see from here:
http://www.youtube.com/watch?v=stcy4q2qIZs
So it is working. However from your explanation I was told you are speaking of DSOs, that's why you are saying to wait 30 seconds.
But I was trying to capture images from nearest buildings, stars, the Moon...
I don't know what to put here on this screen:
http://i.imgur.com/ljRwf7l.png
For example, let's say I am trying to capture the Moon. The camera is plugged, if needed you may adjust the focus... but what should I insert there in the GAIN, exp (ms) settings?
I was told for example to use between 12-20 ms to capture the Moon plus 1% gain. But in there you can only see a number (3600) for gain (not a %) and for exp (ms) you can see 0,000. So in this case, 12 ms would be 12 or 0,012? I don't get it.
What about the other options, such as PROFILE: MOON, Filter (currently L), GAMMA, Exp Range (currently 1.00-200 ms), Night mode (default: disabled), Binning 2x2, 16 bit... etc.?
The Firecapture website does not explain in details these settings.
I assumed you could capture anything at night if the telescope pointed out and the object had sufficient light to be seen when not using the ASI120MC and watching from the eyepiece perspective.
For example, if I point the telescope to a building where the room is illuminated using any eyepiece the image seems clear to me. Now if I put the ASI camera with all those default settings I can't see anything at all and the camera goes crazy perhaps because specific settings needs to be used for specific targets.
That was not the case when I tried to observe 10 A.M. a coconut as you can see from the Youtube picture. That didn't please me and I got frustrated after a while. However I wasn't able either to point to the Moon which would be the best object to do a test yesterday at night.
I mean, it's one thing to see a black screen and any object that needs a little adjustment in focus to form a picture, and another to fail completely to capture anything with the cam. That's why I thought the camera was defective.
