I use my 120MM for solar imaging and usually get very good results. However, in the last few weeks I have noticed I am getting a vertical noise pattern in my images - see the photo attached, you will see it best if you zoom in on the image. The capture info is below:
ROI=1280x960
FPS (avg.)=16
Shutter=0.405ms
Gain=13
USBTraffic=53
AutoExposure=off
Brightness=0
Gamma=41
Histogramm(min)=2
Histogramm(max)=196
Histogramm=76%
Noise(avg.deviation)=10.08
Limit=1200 Frames
Sensor temperature=25.0 °C / 77.0 °F
Can anyone advise on the origin of this noise and how I can get rid of it?
I shot a video of the sky (defocussed so no detail) under the same exposure settings and processed it with a lot of stretch on the image and got the second photo attached. Is this the origin?
I note that so far I haven't seen this with video recorded at 2.26ms exposure.
Any advice appreciated.
Gordon
