Hi All,
I have a problem with the new AsiAir Plus 256G
This happened on TWO new machines so i am thinking it's a hardware or bug problem of the new platform.
After a short time of operation the Input Power Meter hangs and stays stuck on a number no matter what a change in the power outputs (connect/disconned dew heaters, camera, cooling on/off).
Very difficult to manage power consumption when out in the field on batteries.
Anyone had this problem?
@Zwo any solutions?
Thanks
Note:
Had on one new machine, returned it just to have same problem with replacement one.
this happens also if no hardware is connected to the AA+256,
i am powering with a Zwo power supply the AA+256 only directly or with batteries
From different devices
Rebooting the app does not help, only a full AA+ reboot works ...for a period
The only part that changes is the temperature of the CPU, the other measures are stuck
Outputs switching seems to work, cooling starts etc but no changes in the measures current
