I am using mine that way with no issues. The only problem you may have is without some sort of regulator, it will be at full heat the whole time. If you set up the power channel as "dew heater" it gives you an option of a slider to limit the output which should help that somewhat. But yes, perfectly "dew-able" ;-)
