I have just upgraded to a ZWO ASI120MC from a NexImage 5.
Due to clouds and rain, all my work so far has been in my recreation room in the basement, seeing what the software will do for me before I try it outside with my CPC 800.
So far, I have found that the XP netbook I was using for the NexImage 5 just isn't robust enough to use with the ZWO. That's OK, I can use my wife's notebook, a Win7 Home 64 bit.
I can get all both Sharp Cap2 and FireCapture to operate the camera on my desktop, but the notebook is balking at the FireCapture Software. On my desktop pc it starts fine, but on the notebook it fails every time, and I see a message that it cannot find the start.bat file. However the start.bat file is right where it should be, in the same folder as the .exe file. I tried running it as an administrator, and turning off the virus protection, and running it in compatibility mode, which it recommended for XP SP2 mode. Nothing helps, so I am temporarily giving up on FireCapture for now, and just using SharpCap 2.
Any suggestions as to a fix for FireCapture will be appreciated, as I've run out of ideas.
- Ted in Ohio
