billgarlic
billgarlic random exposure failures (no consistency of timing or cause I can see)
Did you try different USB cables? if the problem still appears, please submit the log in the ASIAIR app(About -> feedback)
billgarlic temperature variations where the fan seems to shut itself off completely and then slowly ramps up again
The camera works in a short exposure for a long time will cause the cooling can not stay in a stable temperature, you can set a interval time, such as 1s.
billgarlic when you plug and unplug the camera the temp display no longer shows in the app.
Could you take a screenshot to show us the problem? thanks.
