I have used autorun mode since I started using the ASIAir mini a few months ago, but last night I tried Plan for the first time. I had it shoot 20 shots at M94, then move to M63 for 30 shots. Everything seemed to go well, including guiding and meridian flips. All my frames of the first target, M94, were saved normally. For the second target, M93, the shots were apparently taken, but none of them were saved. It created a folder for M93, but the folder is empty. I am saving files directly to a USB drive plugged into the mini's USB port, but I've never had a problem with this before. Any suggestions?
Edit: I just learned that although the Plan mode did save my shots in the first target folder (M94), those fit files are not recognized by my processing program, APP. But my flat files, which were saved under Autorun, are fine. So does the ASIAir save files differently under Plan compared to Autorun?
