Hello,
I can’t seem to find this information in the list of threads so if someone has a reference or can help I’d appreciate it.
Plate Solve failed while trying to plate solve a stored image taken with the same setup at an earlier session. My image parameters were the same as the image taken.
I was trying to use the GOTO feature in the Image Management/ select your image/ GOTO tree.
Thanks
Hello, do you mean that in image management, the image taken before cannot be plate solved?
2 years later
Yes, that’s what I mean. Thank you.
Write a Reply...
