I noticed a problem when programming an autorun Capture in ASIImag.
I did programmed a line with light 30 secondes capture.
I had others lines un-checked, because I want to keep them but not use them at this time (witch is perhaps the origin of my problem).
I did get 31 captures for all night,...
When captures begins, I got in one hour about 30 minutes of capture every 30 secondes, then nothing during about one our, the 2 ou 3 captures for the next hour, then nothing then an other one ou two captures...
I also have some "white" images captured, in fact they are corrupted images...
What can be the problem? thank you.
Here are the logs, (nothing special...-)
2023-05-21 00:32:03.068 [I] Set Exposure: 30s
2023-05-21 00:32:05.121 [I] CurrentPosAndSize: posX:0 posY:0 width:3840 height:2160
2023-05-21 00:32:05.122 [I] AsiCamera startToExposure!
2023-05-21 06:41:31.896 [I] AsiCamera stopExposuring!
2023-05-21 06:41:31.924 [I] Close Camera Successfully!
I'm using the 1.8.2 version, on a MacBook pro MacOS 13.3.1
