I have a simple question.  I set up Plan last evening to capture two different objects.  I couldn't see a way to set it up so capture on the first object started at a certain time and the capture on the second started an hour after the first.  To capture both before the light of day, I had to adjust number of frames for each to make sure the combined run time was before daybreak.  Do I make two different Plans to start the same night or can i delay the second object start time?
