I have succesfuly been able to use my AM5 mount lower than -23C (-25C) last weekend without any issue š
I used another dew heater band for a 5 inched dia. telescope, and i've rolled it up arround the DEC axis.
I've set it up at 90% heat on the ASIAIR Plus control, and it really help warming up the AM5.
Last time before without using any heater, at -23C my AM5 was unable to drive the axis a full speed without overloading.
I've checked the temp of the AM5 outside casing with an infrared heat gun, and the dew heater band was able to transfer some heat way below the DEC shaft.
Also using a longer tan needed dew heater band just helped to keep some heat by insulating the the DEC axis and was not causing any interferences while moving the rotary axis.
Just want to share my last attempt
Ben
