Does ASIAIR Sky Atlas work with a CPC wedge South EQ alignement?
I seem to be able to plate solve for a PA but go-to is upside down like I am in the North.  I was using the Celestron GEM in the settings instead and got it to PA, plate solve and track, but this is where the compatibility ended.   Otherwise I got it to work for most other things.
Also will the new camera rotator work with Alt AZ mounts to track and de-rotate the field rotation like some other camera rotation devices do?.
Thank you in advance.
