Hope all is well. Having a crazy issue with my AM5. I’ve had it for a couple of months and never had a power issue. I use one power source connected to the mount. I have a ASI Air, ASI 2600 MC Pro, 2 dew heaters, EAF, ASI 120 MM with a C-11 Now the mount seems to loose connection and disconnects all items attached to the ASI Air due to not enough power. I then put two power sources one for the AM5 and one for the ASI AIR and it still disconnecting from the network? What’s going on?
