PhotomanTom
It is also there, but when you transfer files or choose them, you have to see it yourself visually, or you cannot do it. If filename is short and cryptic, you should open them one by one with a program capable to show you that information to find out where to put them. For example darks taken in different temperature and time and date should be able to put into appropriate folder. Easiest way is just choose them from folder list according the name and drag into appropriate folder in your storage drive.
