May be a stupid question but can you use the usb c port on the asi air plus to plug into a Zwo asi174 camera
No, the USB-C port is only for connecting to a PC to download images. You can't even run an imaging session if the USB-C port is connected, from what I understand.
Ok kind of figured that but wanted to ask.Thanks don’t have a cooled camera so I’m short on usb ports
No worries! Out of curiosity, what all do you have connected? Main camera, guide camera, focuser, & mount by the sounds of it? I wonder if you might be able to strap in a powered USB hub and connect that inline, to give you a few more ports?
Yeah all that and efw I’m getting conflicting info and also don’t too much on my ota. Any suggestions and can it be powered off the asi air power ports? Thanks so much!
