rms401
Thanks for your suggestions.
According to the dark current curve, you will find that there is no significant difference in dark current noise after the temperature is below -5 degrees, which means lower temperature does not bring much improvement in the signal-to-noise ratio.
You can calibrate it via dark and bias, and stack more light frames to improve SNR.
