For the last few nights all was going fine with my setup. Then, last night when I tried to auto slew to my target for the night my ASI Air restarted a second or two after I initiated the GoTo from the ASI software. Once the ASI restarts I try to initiate the goto again, and once again it restarts.
I am powering my ASI Air with a 12v 5a power adapter plugged into main power. My mount and camera are both being powered through the ASI Air. I thought it was the power to the mount so I powered it with its own 12 V connection. Still when I initiate the GoTo the ASI Air restarts.
I have also tried to initiate the GoTo from another Deive and the same thing happens. It restarts and I am not able to GoTo my Target.
Any help or advice would be appreciated.
Thank You,
David
Equipment:
Mount: Skywatcher HEQ 5 Pro
Scopes: SVBONY SV503 Telescope 80ED
Cameras: ZWO ASI 533mm
Other: ZWO EAFs, ZWO EFWs, ZWO ASIAIR Plus, ZWO Filter Wheel
