Spaceknight17 Is it maybe possible, that I send someone my sd card, who can put the necessary information on it?
Why not do it yourself?
The easiest is if you have saved a disk image of the SD card when you first received the ASIAIR (the recommend approach when you first unbox the ASIAIR).
If you did not do that, go download a disk image of the original firmware by following the instructions here:
https://astronomy-imaging-camera.com/manuals/How_to_Restore_ASIAIR_OS.pdf
Be sure to click on the ASIAIR PRO link and not the ASIAIR link.
Beware that it is a huge file (unlike Raspbian NOOBS, INDIGO Sky, etc), ZWO did not bother (or does not know how to) compress it and let it expand the first time it is used. Even empty space of the 32 GB image is left uncompressed.
If the program (e.g., Apple Pi Baker) fails, you may have formatted the microSD card (ZWO calls it by the very old name, TF Card) into something unrecognizable. The simplest thing to do is to go buy this particular Samsung microSD card that ZWO uses from Amazon:
https://www.amazon.com/SAMSUNG-32GB-MicroSDHC-Adapter-Model/dp/B0749KG1JK
Do not buy any other brands' 32 GB card, since ZWO assumes a slightly oversized image that fits the Samgung, but is known not to fit in some other microSD brands' "32 GB" card.
However, the better thing you can do is to buy anybody's 64 GB microSD card (which is often cheaper than buying the 32 GB Samsung; even a 64 GB Samsing card nowadays is cheaper than that 32 GB Samsung card :-). The way ZWO had created the image, it will not make use of the entire 64 GB on the physical card, but should work as a slightly oversized "32 GB" card.
Desperatly waiting for support.
Don't hold your breath. Once you have used more ZWO products, you will learn that ZWO is not known to offer timely support nor repairs. They will sell you something and take your money at an augenblick, as you Germans say, though. A different company would already have DHL'ed a working microSD card to you.
