Hi. I love my ASIAIRs and use them all the time. However, I really miss a feature from SharpCap that allows my EAA sessions to be more fruitful - an FWHM filter. Allowing to see the FWHM of frames, and set a limit above which the frame is discarded. This is great for windy conditions where the wind or a knock on the tripod causes a frame to be bad. One frame wouldn't be a problem, but the problem is that wind tends to create a pattern in these and spread all the stars/objects in the same direction - which gets registered in the final image. Please implement for live stacking!
A nice to have might also be a brightness filter - so that live stacking stops if the brightness goes above or below a threshold - this allows handling clouds or dawn creeping upon the images and messing them up...
