Last after capturing all my lights I stopped the sequence and set up a new sequence to capture my dark frames. I clicked the "dark" box so it would set up a "dark" folder. I put the front cap on the telescope and did the AutoRun sequence. It appeared to work and there are no error messages in the log.
After stacking I found weird things happening. When I checked the dark frames they all had star data in them! The cap was on so it must have been data from a previous light capture. I lost 45 minutes of time capturing what I thought were dark frames.
To be clear, in the ASI Autorun directory there are two folders labeled Light and Dark. The light folder has all the correct light data, and the Dark folder has the correct number of dark frames, all time-stamped correctly. However there is a star field in each frame!
Does anyone have any idea what is going on?
Thanks!
Neil
