Hi, Chen
Thanks for the EAF tem probe hack. I assembled two of them using generic 100k ohm thermistors purchase on Amazon
'HiLetgo 10pcs 3D Printer NTC Thermistor 100 K Accuracy 1% B Value Temperature Sensor 3D Printer Parts'
(not sure if secondary vendor links are allowed).
Both of my probe tremperatures report temperatures 7-15 degrees higher than the ZWO extgernal probe- which closely matches 2 digital thermometers that I tested it with. I soldered to the tip and sleeve, carefully avoiding the ring tip and any other conttact.
Could you refer me to the correct thermistor? The generic ones I see are for 3D printers; perhaps the ones I purchased are all junk.
Many thanks,
Gary R.
