- Up-to-date user manuals for beginners. Especially for the ASIAir
- For the AM5, provide guiding estimates based on the provided PE graph. Or at least a write-up on how to tune the parameters based on imaging scale and seeing.
- Expose more of PHD2 in the next iteration of the ASIAir App. Especially Guiding Assistant.
- Make guide logs available in modes other than Auto Run and Plan
- Solve the issue with time zones once and for all. Obviously wrong LST calculations by the ASIAir is getting annoying. Especially since I can't get meridian flips to work consistently with my mounts regardless of DST settings.
- Ability to turn on/off power ports in Auto Run and Plan modes. For example, automating flats by controlling the flat panel.
ZWO should just hire Chen @w7ay as a consultant and be done with it... ;-)
