In reference to my previous post (http://zwoug.org/viewtopic.php?p=2925#p2925), my replacement cooling fan arrived. I attached it to the heat sink already mounted to my ASI120MM, then started up FireCapture running continuous 10-second dark frame exposures (1280x960 in 8-bit mode) with the gain set at 100. After the camera had a chance to warm up, I turned on the TEC.
Um . . . holy moly. The temperature reported by the sensor on the CMOS chip dropped by 33.4 degrees C (60 deg. F) in five minutes! The mean noise reported by FireCapture's histogram function dropped from 54 to 1.02 counts (that is not a typo!). Ambient was about 23C (74F). When I turned on the TEC the CMOS chip was reporting 24.2C, and it subsequently went down to -9.2C. See the attached plot.
Flagstaff has a dry climate, but with that kind of temperature drop I may need to add a desiccant, similar to what ags did (http://zwoug.org/viewtopic.php?p=2782#p2782).
