I can set my flatfield panel via the port on the ASIAir Pro. However, I can't turn it on/off from the planner which makes automatically creating flats impossible.
Simplest solution would be to turn on 12V ports that are assigned as "flatfield" automatically on when creating flats. Even better would be a setting for each object in planning that can control the 12V ports.
Is there any way to do this? Maybe even with a hack from command line?
Write a Reply...
