Kevin_A that means they have probably got hold of a 150:1 strainwave head.
ZWO's specs states otherwise, though: that the new strain wave gear is still spec'ed at 100:1. So, the change in the ratio has to come from somewhere else?
Further, this review of the WD-17 lists the ratios for different strain wave geared mounts (the most comprehensive table I have seen yet):
https://walachia.blog.fc2.com/blog-date-202302.html
Notice that it too lists a 100:1 strain wave gear ratio for the ZWO mount (Google translate works rather well even for the table:-). But "reduction ratio" is listed as 300:1. Not 150:1, which is needed (for a strain wave period) to produce a 287 second period (correcting my mistake that a 100:1 strain wave gear produces a period of sidereal day/100 instead of sidereal day/200).
(Thus, I think that 300:1 is a mistake and it is the reduction in periodicity of the strain wave gear, not reduction in gear ratio -- and the ZWO mount really has a 150:1 total reduction ratio.)
Notice that for the WD-17, the gears are listed as direct drive, with 100:1 gears and reduction ratio of 100:1 -- thus, because of the stain wave repeats, a period of sidereal day / 200. I.e., 430 seconds, and not 860 seconds (same as RST-135 period and the period of your version of the AM5). Makes it a little less interesting to buy one to measure, but I'm still tempted to pull the trigger.
(By the way, the author had a question right after the table about BLDC vs DC servo motors -- I believe BLDC simply implies a brushless DC motor, where there is no commutator, and the currents to the motor coils are simply modulated at different phases. So, still just a DC servo motor -- the one in the RST-135 is probably brushless too.)
We do know that there is a belt in the ZWO mount. There is also supposedly one in the RST-135, but I have not opened my mounts far enough to see it. This is what the RST-135E looks like after removing two layers of printed circuit board. Already past the warranty boundary :-). That thin barrel marked with [2.5] is not present in the non-E version of the mount:
Yes, my mistake on the 100:1 producing an 860 second period. Definitely my bad. Even the NASA paper that I linked to had mentioned that it takes two revolutions for the strain wave to repeat (I think the Wikipedia page also mentions it), so a 100:1 strain wave gear would repeat like a 200:1 "standard" gear ratio. I should have remembered that. Bloody rotting brains.
Kevin, I went completely the other direction last night; no tracking, no guiding; only used the mount to GOTO :-).
I was doing a practice run for the Perseids tonight, and simply parked the mount near the Zenith just a few minutes west of the Meridian.
I had shut tracking completely down -- but ASIAIR proceeded to turn it back on behind my back at some point (good thing I was watching) -- so I removed the mount from ASIAIR completely to get what I wanted, instead of what ASIAIR wanted.
I was running a 50mm lens (f/1.2 - yes, wide open with bloated stars and so on :-) on a full frame ASI6200C that is so wide that it would not allow me to track for even two hours because of the trees -- so I simply parked the mount and used 6 second exposures. I figured that except for a fireball, a meteor would not last for more than 3 seconds, and the 6 second exposure will minimize my sky background noise. The 6-second untracked stars also minimized the streaking.
(ASIAIR "auto-focus" is completely useless at f/1.2 of course.)
Anyway, I will be parking the lens a little east of the meridian tonight (as far as the trees will let me), and a declination a little north of Zenith (my Zenith declination is +45.45º), again as far as the trees will allow me, to get nearer to the radiant when it comes past.
So, no autoguiding, no tracking, no mount later tonight :-).
