Tech@ZWO I am curious if this "custom park position" feature has been added, or is still going to be added for other mounts (non-ZWO mounts) when using the ASIAir Plus? I am heavily contemplating constructing an observatory and would need the ability to have a custom park position. Right now I believe I would need to discard the ASIAir Plus and switch to NINA to be able to do so. I would much rather stick to what I know, the ASIAir Plus.
If we could slew the mount to a given position by way of the manual slew controls, with tracking disabled, and a button marked "set custom park" under the mount menu to set the position as the custom park position would be much appreciated. Of course also add a "GoTo custom park" button under the mount menu as well. Additionally, if the "custom park" (after being set as stated above) could be added to the sequence in plan or auto run mode as opposed to "go home" would be exceptional.
I would not want a "custom park" setting to completely replace the go home feature of the ASIAir Plus. Obviously a go home command is still a very useful feature for many reasons.
Having a custom park feature on the ASIAir Plus could remove a reason someone may choose not to purchase an ASIAir Plus. Obviously this pertains to someone looking to install an observatory and may not already be using NINA or an ASIAir.
