Suhndog77
Are you referring to the location on the Seestar page or the location when you post the image?
Seestar prioritizes the use of automatically acquired locations, and if Seestar has gotten the location, you do not need to set the location manually.
If you want to edit the location anyway, you can turn off the Location permission in your system settings and restart the Seestar app, then you can edit location manually.
