The ZWO FF130 is just a rebadged Askar 130PHQ OTA. (Given how ZWO appears to treat warranty requests, buying an Askar OTA from a local vendor would have given you better warranty protection.)
When used without a reducer, to find the focus location of the Askar 130PHQ, first rack the focuser so that the drawtube is fully retracted. At that point, the focal plane is 99mm away from the metal back of the 54mm adapter (79mm from the metal back of the 48mm adapter). This is the maximum distance your camera's sensor can be away from the OTA and still be able to focus.
Mark that location on your table. Now rack the focuser all the way out. If the metal back of the drawtube does not reach the maximum position in the previous paragraph, you will need to add spacers.
If you use a reducer from Askar, the camera sensor needs to be precisely 55mm from the metal back of the reducer when using the 48mm adapter (62.5mm from the reducer's 54mm adapter).
Remember to subtract 17.5mm for the distance of the ASI294 flange to its sensor. And add 1/3 the thickness of the filter glass, if you have a filter in the light path.
